Help! Cross Referencing!
Old Jan 9, 2011 | 01:25 PM
skatelove303's Avatar
Default Help! Cross Referencing!
Hey guys im in dire need of a Rear oil seal and i cant seem to find it anywhere! Everyone has the bearings but not the seal... Does anyone know of a vehicle i would be able to X ref with? Im sure there are a couple different vehicles with the same size seal. PLEASE HELP
Old Jan 9, 2011 | 02:28 PM
http://www.roverparts.com/Parts/9002D.cfm
What part exactly are you looking for? Is it in that kit?
Old Jan 9, 2011 | 03:19 PM
Hub oil seal rear
Old Jan 9, 2011 | 03:33 PM
lordmorpheus's Avatar
FTC5268 doesn't cross to Federal Mogul or Chicago Rawhide. I have a feeling you aren't going to be able to find locally and will have to order it from a LR supplier.
Old Jan 9, 2011 | 03:38 PM
Originally Posted by skatelove303
Hub oil seal rear
There are 2 hub oil seals.
The small one that slides onto the axle shaft can be left out, just make sure that you raise the rear of the truck and over fill the rear diff.
And then tip the truck so that the side without the seal is lower than the other side.
Let it sit for 15 min and then you are good to go.
The seal that goes between the stub axle and the hub needs to be in place.
You can only get that from a LR parts supplier.
TRIARII
Off Topic
Nov 2, 2014 06:31 AM
TRIARII
ROAMING WITH FRIENDS
Oct 19, 2014 09:30 PM
fri3daz3
Dec 9, 2008 12:19 PM
HorizonDesire
Jan 30, 2007 11:31 PM
Broms
Dec 13, 2004 10:37 PM
