Help with disco 2 driveshaft intall in to disco 1
Old Jan 9, 2014 | 01:53 AM
Murph9265's Avatar
Default Help with disco 2 driveshaft intall in to disco 1
I am currently working on my 1996 Discovery. Ive installed the 3" springs, new shocks and mounts and im currently changing the drive shafts. What I need to know is, what flange do I buy for the front to install a disco 2 front shaft into my disco 1? Also, Id like to find some extended brake lines and front sway bar hitting driveshaft help.
Thanks,
Nathan
Old Jan 9, 2014 | 05:59 AM
Matt_Attack352's Avatar
Cant help on the shafts, mine has great basins under it. As far as brake lines, most ss brake line kits I saw ran about 60 to 80 for the +2" sets. All four corners. Oicj your favorite distributor or do a little price searching. Britpart, terrafirma, rovertym, etc all carry/make lines. GL on the drive shaft install!
Old Jan 9, 2014 | 06:16 AM
antichrist's Avatar
You need a DII LT230 front output flange.
That said, have you read this? Tom Wood's Custom Drive Shafts - Driveline 101
Old Jan 9, 2014 | 08:05 AM
fishEH's Avatar
-Lose the sway bar.
-Get the flange Tom mentioned.
-With a 3" lift I wouldn't futz around with +2" lines. Mine stretched to the max a couple times. I'd recommend going with Part# *PPB-LRDIS96MC, from here. Land Rover/Range Rover Stainless Steel Braided Brake Lines
They were very nice to deal with, offer a web forum discount(ask), and you get to choose your PVC jacket color.
Old Jan 9, 2014 | 11:31 AM
Murph9265's Avatar
Great info, thanks for the help! I'll get some parts ordered and get them installed.
Old Jan 9, 2014 | 01:34 PM
Originally Posted by fishEH
-Lose the sway bar.
Dang, those lines are nice. may have to grab a set as i haven't fitted the SS lines that were under my rear seats when i bought the truck.
Good luck on your install, glad someone chimed in and helped you quick!
Old Jan 9, 2014 | 02:06 PM
fishEH's Avatar
These are the Paragon 25" lines with a Smoke jackets compared to the GoodRidge +2" Lines with a Clear jacket.
Here you can see why I needed something more than the standard +2" lines with 3" springs.
Old Jan 9, 2014 | 04:27 PM
dusty1's Avatar
Show off... What +size ax stops do you have stuffed in there? I kind of see the left, +2?
Old Jan 9, 2014 | 05:27 PM
Oh those are nniiccee. May have to snag a set before our feb trail day.
Old Jan 9, 2014 | 06:07 PM
CUpgt's Avatar
I run them as well. Nice lines and a good price.
