Help! ECU loses power when rainy
Old May 27, 2016 | 12:43 PM
GRAVZZY's Avatar
Default Help! ECU loses power when rainy
Hi,
I have this issue since the end of winter with my 1998 D1 v8 (GEMS). With heavy rain or at the car wash the truck dies and stays stranded until the engine bay has dried out. I had the truck towed back home three times and the only way to get it to start and run well again is to let it in the garage overnight with a heater under the hood. I've checked underhood plugs and grounds and I opened une ECU box to blow air in it and make sure it's dry, but only time, air and heat does it. When the problem occurs, the check engine light flashes and relays and actuators controlled by the ECU flickers (AC fan, EVAP solenoid, etc). Has this problem ever happened to another forum member and if so does any of you have a clue of where to look next? Common gremlin?
Thanks!
Old May 28, 2016 | 05:36 PM
TOM R's Avatar
Pull ecu are there holes in the wheel well?
All plugs on this car need to be unplugged , dielectric grease, plug back in, stop power washing the engine bay
Other issue could be crank sensor wiring is poo and shorting
Old May 29, 2016 | 08:26 AM
GRAVZZY's Avatar
I don't think the crankshaft position sensor could cause the ECU to loose power, it would sure cause weird running problems or no start but doesn't explain the check engine light flickering and the triping relays and actuators... But I might take a look anyways to see how rotten the sensor is... I hurry being able to use the truck in the rain again as I feel like a frustrated Ferrari owner now...
Alabama Butthead
Oct 11, 2014 03:00 PM
chief78
Dec 4, 2012 01:53 PM
discoken
Mar 25, 2009 09:30 AM
christians1600
Mar 18, 2008 09:33 AM
soupdogg
Sep 25, 2007 12:49 PM
