Help! Fender Blinker Light Fell into Fender
Old Jun 23, 2016 | 06:35 PM
colemtd's Avatar
Default Help! Fender Blinker Light Fell into Fender
Hi All, I have a minor issue:
I went through an automated car wash and I think that's where I lost the cover or case to my blinker light on the fender. I went to an aftermarket parts store to get another cover but now the blinker bulb that goes into the cover fell back into the fender. I tried to use a flashlight to see if I could see the bulb through the hole in the fender where the cover goes but I couldn't see anything. I looked under the truck but couldn't see up into the fender area.
Any ideas on what I could use to fish out the bulb and wire from in the fender or should I just superglue the case onto the fender and leave well enough alone? LOL..
Old Jun 23, 2016 | 08:05 PM
stillruns's Avatar
You were able to take a DI through a car wash and not come out the other side soaked, lol?
Old Jun 23, 2016 | 08:51 PM
fishEH's Avatar
Sounds like you need a new one of these.
Land Rover Replacement Lamp Side Repeater, On Wing, Orange - PRC9916
You might be able to use a metal coat hanger to fish out the wire.
Old Jun 23, 2016 | 09:25 PM
colemtd's Avatar
Ha Ha!!
Old Jun 23, 2016 | 09:27 PM
colemtd's Avatar
Very Funny!
Old Jun 23, 2016 | 09:28 PM
colemtd's Avatar
Hey Fish!! Long time!! How have you been? Thanks for the advice. I will try it..
Old Jun 23, 2016 | 09:39 PM
fishEH's Avatar
I'm good!! If the coat hanger fails its only about 6 Phillips screws and a few bolts in the door jamb to pull the fender, at least pull it out enough to find the wire harness.
Old Jun 23, 2016 | 10:08 PM
colemtd's Avatar
OK, thanks!
Old Jun 24, 2016 | 08:36 AM
Jagfixer's Avatar
The inner fender liner can be moved enough to see inside the fender, buld and socket probably there.
Old Jun 24, 2016 | 09:31 AM
Racer X's Avatar
This is my suggestion as well. Easier than removing the entire wing.
