HELP - Shorted something
#41
#43
#45
What he said. :-)
However something concerns me.... NEGATIVE BATTERY CABLE TO MF5!!!!! NO NO NO!
Please tell me that you made a mistake typing that. It should be the POSITIVE cable.
Otherwise I'm guessing your truck is toast.
Assuming that that's a mistake, was there 12V on BOTH sides of MF5?
#48
If NO lights come on at position 2, consider the oil light. It gets a ground thru the block. It gets battery voltage via the ignition switch, the closed oil psi switch, F14, via MF5 and the ignition switch - yellow wire.
One convuluted test would be to unplug F14 under dash. Read for ohm (continuity) between each side of the fuse holder pins and chassis ground. Should see ohms on one side to ground. Extend meter lead (they are never long enough) and read from the other side of F 14 (un-grounded) to MF5 for ohms. May have to slip off battery cable to prevent normal 12 volts from skewing meter reading.
Either ignition switch is fried, or junction/splice S233. Wonder where that is.... with "2" it should be between firewall and cigar lighter in what would be thought of as the dash area.
See attached page 343 of 591 of the electrical guide (97).
Wonder if these wires for S233 splice are the same as pictured? Or nearby?
#49
Im confused. I thought you said to check voltage between MF5 and a ground. Isnt the neg cable a ground?
I clipped the black probe to the bolt on the neg cable and put the red probe on each fuse screw.
Regardless, nothing exploded and yes, 12v to both sides of MF5
#50
I think he means measure between negative cable and MF5. But this is slow, like playing chess by snail mail.
