HelpOxygen Sensor Question!
Hi All,
How many Oxygen Sensors does my truck have?
And what is the significance of buyer one With Advanced Evaporative Loss System (AELS) vs buying one Except Advanced Evaporative Loss System (AELS)?
Thanks for the help! I need to change my sensor soon so any advice would be appreciated!
I'm assuming w a 99 you have AELS. Its two different sensors for two different systems. Or at least that's how I researched it. You should have 4 sensors total. Two on each side of the y pipe. You will have two before the catalytic converter (upstream) and two after (downstream). I don't remember if the up stream or down stream are different part numbers but they all install the same way.
I bought four of mine at autozone (Bosch) and they worked great.
colemtd (12-08-2014)
4 O2 sensors. If you still have the decal under the bonnet check the Emissions Group.
How To Identify The Evaporative Emissions Family Of Your Discovery 1
And when I do find the decal will it say something about AELS on it?
Also, who is the Emissions Group?
