Hi lift, shovel, axe, tube mounts
Made this pair for Turfs new SD rack and hi lift - I can make this for any size tube if you want some let me know. If you want a pair I can make them for $45 shipped.
I can also make them to work with shovels, axes etc as long as you're willing to drill two 3/8" holes in whatever they are and tell me the thickness of it.
Can I get a pic of the CB mount?
I could but after discussing it with Turf he decided this would be the route to go.. DAC TECHNOLOGIES Safes / Security dac cable gun lock, cl200b - www.Outdoor-Sports-Store.com
Just because I could use a 1/2" bolt on it but then even if I drill that out the lock is going to be tiny and in my opinion useless.
Yes I only need to know what size bore the clamp should be.. measure as so
Sounds good just let me know - I can go up to 1 1/2" bore with the collars you see on the first set I made.. I cant imagine the ARB being any bigger than than that but it might be....
