Hi lift, shovel, axe, tube mounts
Old May 10, 2012 | 05:20 PM
Jake1996D1's Avatar
Default Hi lift, shovel, axe, tube mounts
Made this pair for Turfs new SD rack and hi lift - I can make this for any size tube if you want some let me know. If you want a pair I can make them for $45 shipped.
I can also make them to work with shovels, axes etc as long as you're willing to drill two 3/8" holes in whatever they are and tell me the thickness of it.
Old May 10, 2012 | 05:42 PM
wheelgarage's Avatar
Need to work on mounting a fishing pole container....just need to find one first and find out if I can use this type of mount.
I have one that mounts a CB antenna on my rack. You might want to add that to your list if you can.
Old May 10, 2012 | 05:53 PM
Jake1996D1's Avatar
Can I get a pic of the CB mount?
Old May 10, 2012 | 07:39 PM
Can you drill a hole in the threads to make it lockable?
You just need a outside diameter of the tube right?
Old May 10, 2012 | 07:58 PM
Jake1996D1's Avatar
I could but after discussing it with Turf he decided this would be the route to go.. DAC TECHNOLOGIES Safes / Security dac cable gun lock, cl200b - www.Outdoor-Sports-Store.com
Just because I could use a 1/2" bolt on it but then even if I drill that out the lock is going to be tiny and in my opinion useless.
Yes I only need to know what size bore the clamp should be.. measure as so
Old May 10, 2012 | 09:02 PM
Sweet.
Thanks Jake.
Fathers Day isn't that far away.
I will let you know the size a few weeks before I'm ready to buy, it will be going on my ARB bumper.
Or maybe the back of my SD rack...decisions decisions...
Old May 10, 2012 | 09:14 PM
Jake1996D1's Avatar
Sweet.
Thanks Jake.
Sounds good just let me know - I can go up to 1 1/2" bore with the collars you see on the first set I made.. I cant imagine the ARB being any bigger than than that but it might be....
Old May 10, 2012 | 10:16 PM
fishEH's Avatar
Nice job on those, Jake. I might be able to squeeze my Hi-Lift behind my spare tire.
Old May 10, 2012 | 11:25 PM
Jake1996D1's Avatar
Thanks bud let me know if you need me to make something up for you
Old May 10, 2012 | 11:42 PM
Just got back from the park. I'll shoot the pic tomorrow morning when there is light...
