HI new and Help!
HI new and Help!
hi
i just bought a 97 disco and it has a problem. it seems that something gets heat soaked and it will start to stumble. and if it sits in a hot parking lot it will not start. today i put a bag of ice on top of the coil area and on the intake and it started in a few min. when it stumbles you can here it back fire through the intake.
any ideas?
also it has a check eng light and i assumed it is obd II being 1997. but i don't know where the connector is.
thanks Greg
any ideas?
thanks Greg
got all the codes read. it was giving all the missfire codes. i checked the fuel and it is giving good pressure. plus when it's crapping out you can smell fuel in the exhaust.
is there a ignition module any where on these things? i see the 4 coils but there seems like there should be a module some where.
i had a car some time ago that did the same thing. the ignition module would get heat soaked and quit running
If it is backfiring you probably have a sticky valve or two.
You MUST use premium gas and if the previous owner did not use premium gas then the oil will bake inside the heads and valley and sludge everything up.
Open the oil filler neck and look inside with a flashlight.
How does it look?
The raw gas you are smelling is unburnt gas coming out the tail pipe.
If a exhaust valve or two are sticking open that can cause mis fires as well as send unburnt gas down the exhaust.
Also a sticky intake valve will cause back fires.
Change the oil and use diesel oil, Shell Rotella 15w-40 to start cleaning things out.
Use a cheap oil filter because you are going to change it again in 500 miles.
The day you change it pour in a can of Marvel Mystery Oil into the crankcase and idle the engine for 30 min and then change it.
If it were not for the back firing then I would say you needed a tune up really bad.
How does it look?
Hey Phil while we are on the subject I have noticed on occasion the smell of fuel after driving, not very often just every once in a while. truck runs pretty good but could use a tune up, got an ignition code a few months back and added a bottle of the Lucas fuel additive stuff with a full tank of gas and about a quarter of the tank later the light was off. have to do things one at a time due to heavy financial restraint so what order do you suggest doing things?
150K on the truck
150K on the truck
