Hood liner
Old 03-25-2012, 12:14 AM
EricTyrrell's Avatar
Old 03-25-2012, 12:54 AM
THAT IS COOL. Wonder where those parts came from?
I was looking really close today as I degreased the whole bottom of the motor and cleaned really well everywhere. It looks like redoing the intake air box into a snorkel would not be too hard and vastly lower input air temp. Wonder what that would do to the ECM?
Old 03-25-2012, 09:50 AM
Not much, as the IAT updates it faster than an ex-wife can call her attorney. The IAT and the MAF values are part of the "weight of air vs. weight of fuel" calculations. It will adapt to maintain the stochiometric ratio. So adding a snorkle won't give you 10 mpg more or faster quarter mile times. But you may be able to do 0-60 in 3.8... gallons. Now if you were on the Autobahn at 130 mph plus, sure, might have some benefits. On stop and go traffic at 45 mph - not so much.
Old 03-25-2012, 09:59 AM
I attached mine with these push in plastic fasteners, don't recall if they were on the D2 or from the blister pack aisle at the parts store. Liner is a little short in front.
Attached Thumbnails Hood liner-p1120437.jpg   Hood liner-p1120436.jpg   Hood liner-p1120435.jpg
Old 03-25-2012, 04:29 PM
That DII liner is no where near as thick as the DI hood liner.
I saved my push button hanger plastic thingy things, I out them back in the hood.
My liner was sagging where it was not fastened.
Old 03-25-2012, 04:32 PM
Originally Posted by EricTyrrell
The hood "scoop" on a RRC is for the HVAC system not for the engine.
Old 03-25-2012, 04:34 PM
Originally Posted by Danny Lee 97 Disco
I agree with Eric, the one in my DI was so full of dust, I ripped it out right away and just cleaned everything up real good. If you put reflective material under the hood, won't it just keep heat in worse?
It would be cool to have some sweet built in scoops like the 1966 Chevelle SS had.
Or even a vent you could pop up with a linkage from inside like some of the real early vehicles had, if you are old enough to have seen those.
The only time heat builds up under the hood is while sitting in traffic or moving really really slow, the cooling system is what keeps the engine cool.
Old 03-25-2012, 06:49 PM
Street Wolf's Avatar
Haven't had mine for years. It's a fire suppression blanket.
Old 03-26-2012, 10:30 AM
Chris-bob's Avatar
There some nice self adhesive heat reflective sound deadening materials out though. That's what I'm planning on.
That's what I plan on using.
Old 03-26-2012, 11:33 AM
if you off road you don't want holes in your hood. it will release trapped air when wading. allowing water to get higher into the engine bay which means bad things for the ecu on a d1 or the fuse box on a d1 or d2.
Quick Reply: Hood liner
