How do i put the CEL out for three hours?
Old Mar 8, 2011 | 04:53 PM
geek_IM's Avatar
Default How do i put the CEL out for three hours?
So long story short I can get it through inspection but I really need the CEL to be out. Binnacle cover is already flopping around due to previous injury. 96 SE7. Any hints are appreciated.
Old Mar 8, 2011 | 05:06 PM
Danny Lee 97 Disco's Avatar
1. You could just remove the bulb.
2. You could pull one of the wires at some point aloing the way.
Have you read and cleared the codes?
Old Mar 8, 2011 | 08:12 PM
Just because the CEL is not lit does not mean it will pass inspection.
And if you remove the bulb and then clear the codes it will come up as "not ready" when they scan it at inspection time.
Old Mar 8, 2011 | 09:04 PM
geek_IM's Avatar
Well, really, the point is that there will be some "hey! look over there!" shenanigans going on at just the right point in time. It just can't be obvious.
To review;
shenanigans + wifey in low cut top + $50 = inspection sticker
Turns out six screws and ten minutes gets the bulb out. Pretty freakin easy.
Old Mar 8, 2011 | 09:13 PM
Gotcha'
Old Mar 9, 2011 | 10:01 AM
groundandpound's Avatar
To review;
Hey - I need to get inspected also - is that "wifeyinalowcuttop" a part specific to your location - I went through every letter of the RAVE and I couldn't find it, although a "GOOGLE" search turned up some results about this same part being able to correct "speedingticketfrom@$$holecop" errors that occur...
Old Mar 9, 2011 | 10:22 AM
calebbo's Avatar
Sticker in hand is the route to go, just befriend a mechanic and explain your situation after a bbq
Old Mar 9, 2011 | 10:35 AM
Chris-bob's Avatar
Mechanics don't get invited to BBQs. And if we do, we immediately suspect an upcoming unpaid job.
Old Mar 9, 2011 | 10:49 AM
calebbo's Avatar
But you still come anyways
Old Mar 9, 2011 | 10:58 AM
Chris-bob's Avatar
Of course, there's food.
