How do you bring faded black bumpers back to life?
this is a pretty common problem in the old watercooled vw world... people have had good luck using peanut butter, the meguirs back to black goop, and ive also had success using a heat gun.
basically anything that removes the oxidation (heat gun) or soaks oils into the plastic (most of the other solutions) should work.
plastic needs to be cleaned with solvents and then very lightly sanded. then put your product on. I prefer dyes or stains to surface paints. I like Forever Black. For things which need cover up, like the grill I properly prepped then used plastic paint and then my flat black.
metal can be cleaned and sanded the same way and then sprayed with a good rustoleum.
my stuff is lasting well so far.
