How heavy is the transmission & T-case together?
Old Jul 22, 2010 | 03:21 PM
Disco Den's Avatar
Default How heavy is the transmission & T-case together?
I'm looking for a transmission jack, & the best option (if it will work) is a wide based floor jack with a transmission adapter. The weight limit on the adapter is 400 pounds. My concern is that the Transmission & t-case assembly is probably pretty close to that limit. Does anyone know how heavy the assembly is?
Old Jul 22, 2010 | 04:08 PM
Long Haul's Avatar
I would think you will be fine with a 400lb rating. I never had mine out but ive replaced the trans an transfer case in my chevy truck that was considerably larger than the disco and the shipping weight on them was 380lbs so I think youll be fine. If you wanted to play it safe you could take the Tcase off separate.
Old Jul 22, 2010 | 07:50 PM
Make sure they are empty and you'll be fine I think.
Blakesrover
Feb 20, 2013 10:31 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
Disco Den
Jul 23, 2010 02:56 PM
05LandRover
Off Topic
Feb 28, 2006 01:34 PM
