How often to replace brake pads?
In the past, people would turn rotors on a lathe and resurface them as long as they still ended up within the width specification. The problem with shops turning rotors is simply too many customer come-backs. There's noise, a shudder in the wheel, a vibration, or whatever. It could be a defective job, or just a hard spot. But after a certain portion of your brake job customers are coming back and your mechanics are re-doing jobs, costing you hours at no additional cost to the customer, you learn to charge the customer for new rotors up front and be done with it. You get more happy customers, and more money. How many shops are going to be willing to save their customers a few bucks by trying to fix their old rotors? More and more of them are saying, "forget it." For the same reason, they're not likely to put new pads on worn rotors. You can probably get away with it most of the time, but if the customer is coming back and you're doing the job again at your own expense, you're not going to keep doing that. You'll advise the customer the first time, their cost for the job will include new rotors.
Wheel bearings will last at least 60,000 to 300,000 miles depending on the type of service they see. If they fail before that, there was a defect in the bearing or the installation. Changing the rotors on the Rover axles is a good opportunity to re-pack the bearings, but it's usually not necessary to replace them or press out the races. Just add some compatible grease and you're good to go. You can check your bearings by trying to wiggle the tire while it's lifted and supported by the axle. If it wobbles, it could just be the hub nut is loose. If you've got over 150,000 miles on the bearings and they've not been changed, you should consider replacing them, especially if your miles are off-road, you have wheel spacers or wheels with less backspacing, oversize tires, or high weight.
