HUB spacers
Old Dec 17, 2012 | 10:16 PM
Discolife's Avatar
Default HUB spacers
Will this get me the wider stance I am looking for?, After fixing the door, Momma wants me to gussy up Ruby........
Hubcentric PNP Wheel Spacers 25mm 5x120 Land Rover Discovery 94 04 | eBay
Old Dec 17, 2012 | 10:42 PM
Jake1996D1's Avatar
Your bolt pattern is 5x6.5.. Those are D2 P38 bolt pattern
Old Dec 18, 2012 | 09:30 AM
Check with Justin at Lucky, he should have what you need.
Before installing the, rebuild your front and rear wheel bears cause those spacer will put a bigger load on them and you don't want them to fail.
Old Dec 18, 2012 | 09:40 PM
dragonhead's Avatar
I've always thought my track looked a little narrow for the truck. These spacers could be what the doctor ordered. Is it recommended to lift the truck if these spacers are used? I'm asking because of my concern for tire rub on the wheel arches.
Old Dec 18, 2012 | 10:22 PM
Discolife's Avatar
Thanks Mike, My axles fornt and back have been rebuilt, was done when the slotted and drilled rotors and brake were rebuilt. Do you know anybody that has done this?
I feel yah Dragon. From the rear view the D1 looks scrawny. I think 25mm would take that look right out.
Old Dec 18, 2012 | 11:13 PM
Jake1996D1's Avatar
What your *** end doesnt look like this??
Old Dec 18, 2012 | 11:17 PM
Discolife's Avatar
I once had a GF with an *** that wide, but no My Ruby is narrow.
SHOW OFF!
Old Dec 19, 2012 | 12:53 AM
Jake1996D1's Avatar
That's not mine but ill get a good *** shot of mine for you
Old Dec 19, 2012 | 09:45 AM
antichrist's Avatar
I like the narrow track of LR's but run rovertyme spacers on the front for a better turning radius.
Old Dec 19, 2012 | 10:23 AM
EricTyrrell's Avatar
Another option is running wolf steel wheels which should give you 11 or 12mm more offset per wheel, IIRC.
