I need an OBD receptacle
Old 07-30-2010, 11:21 AM
Voyageur's Avatar
Default I need an OBD receptacle
Happy Friday...
Not sure if this should go here or under "Classified"
I just found my OBD receptacle, hanging loose under my dash. Vehicle is 1996 Discovery I. I can't find any broken parts or clips that would have held it securely in position so... I guess I need a new (Used) OBD receptacle complete with wiring harness and any clips or devices needed to anchor it back where it should be, firmly attached.
Thanks for any help.
Old 07-30-2010, 12:19 PM
Spencerfitch's Avatar
its most likely because someone removed the foam panel that used to be there that it was mounted to. I wouldn't worry about it. I usually tuck mine away to the right or just use a zip tie to keep in in place, its really not a big deal.
Old 07-30-2010, 01:53 PM
okdiscoguy's Avatar
yup, you have to replace the panel under the dash. It secures in that thing.
Voyageur's Avatar
Thanks Spencerfitch...
I did plug my scanner in with the plugs hanging. I got a "Communications Error" on my Actron scanner so I thought it might have to be grounded against the frame. I guess I have some other OBD problem. The scanner works fine on my wife's 99 Disco II. I appreciate the response...
Old 07-30-2010, 02:07 PM
okdiscoguy's Avatar
Make sure you dont have a blown fuse. Think the cig lighter is the comm power fuse too...
Old 07-30-2010, 02:17 PM
Ah, no it doesn't have to be grounded on anything. As OK said check the fuse if thats not the problem, Im not sure what is, if you absolutly need a new plug I can get you one Im just not sure how where the wiring goes from it, or how difficult it may be to remove the whole harness.
Old 07-30-2010, 02:22 PM
Voyageur's Avatar
Thanks to both of you. Cigarette lighter is good. I run my 276C on it all the time. I'l mess around a little and make sure the receptacle is clean and that I have a good connection. Maybe I'll try "OBD Global" language instead of the Actron "Land Rover" setting. I'll post results...
Old 08-13-2010, 11:47 AM
rasaquan's Avatar
6th Gear
Default OBD plug
I have a 95 and 96 disco where do I find the OBD plug on the vehicle and is it I or II my check engine light is on and I wold like to know what is the problem it runs rough I did a tune up plugs and wires but the same thing NEED Help
Old 08-13-2010, 12:25 PM
discomedic4's Avatar
OBD II connection is under the dash on drivers side. '96 and newer are OBD II. Good luck.
Old 08-14-2010, 01:03 AM
Rover Chris's Avatar
on my 97 I did not have power at the diagnostic connector and found that it goes to the security module for power, I would check all the fuses for a place to start if you are having electrical issues, I have also found that the fuse descriptions in these trucks are not always what they seem!
Quick Reply: I need an OBD receptacle
