Idle fluctuation discovery 1
Old Mar 26, 2011 | 10:39 PM
Optimistic.1's Avatar
Default Idle fluctuation discovery 1
My truck was idling, and fluctuating up and down, and my altinator was making a funny sound, I changed the alternator, and the fluctuating stopped but it still idles high..
Old Mar 27, 2011 | 02:56 PM
Define high idle.
Old Mar 27, 2011 | 03:25 PM
rover11's Avatar
Did you disconnect the negative wire on the battery?
Old Mar 28, 2011 | 07:49 AM
Define high idle? When I start my truck up it shoots two 2000 then drops to bought 1600, i changed the ( MAF) sensor, and the idle control sensor, and oxygen sensor 1 bank 1. Could it be the ( tps ) sensor?
Old Mar 28, 2011 | 10:10 AM
rover11's Avatar
Mine was idling extremely high. It ended up being the exhaust.
Old Mar 28, 2011 | 10:12 AM
Chris-bob's Avatar
Have you downloaded the RAVE and tested the components? Have you tried a search for high idle and tried what has been said before? Do you have and know how to use a Multi-meter? Not trying to be a *****, but there is a wealth of information regarding this topic that has been reposted many times.
Old Mar 28, 2011 | 10:13 AM
Chris-bob's Avatar
Also, what is your 'truck'?
Old Mar 28, 2011 | 04:34 PM
kingnebby's Avatar
I have a 99 LR SD that did the same thing, ended up being the tps
Old Mar 28, 2011 | 06:28 PM
If you already replaced the IACV then I would say its a TPS issue.
Old Mar 29, 2011 | 05:46 AM
I have a 98 land rover disco
nflpa29
Feb 28, 2023 07:04 PM
TDRover
Dec 20, 2014 09:53 AM
dcarr1971
Sep 19, 2012 09:08 AM
westernsun
May 27, 2006 04:24 PM
