Ignition Wire Clips for Valve Cover
Old 12-10-2016 | 05:01 AM
Matt927's Avatar
Default Ignition Wire Clips for Valve Cover
Does anyone know where to purchase the plastic clips that attach to the valve covers where the ignition wires clip into?
Thank you,
Matt
Old 12-11-2016 | 10:01 PM
XCELLER8's Avatar
most any autoparts store should have something in stock that you can use....
Old 12-14-2016 | 08:00 AM
Matt927's Avatar
Going to check today, thank you.
Old 12-14-2016 | 08:35 AM
OverRover's Avatar
I've used this type from Summit for years, and they work spot on ( 7mm or 8mm wire). This type is thicker material and doesn't break like OE. They also have the type with the metal risers (just search Plug Wire Separators).
https://www.summitracing.com/parts/sum-890045/overview/
Squid4life
10-24-2016 10:17 AM
abran
02-13-2015 12:48 PM
OffroadFrance
06-27-2014 01:51 PM
tbesselman
06-03-2005 11:47 AM
Quick Reply: Ignition Wire Clips for Valve Cover
