IM BACK!!!! This time with over heating issues.
Old Sep 29, 2010 | 03:38 PM
rhino_e28's Avatar
Default IM BACK!!!! This time with over heating issues.
Haha, I knew I wouldn't stay away for long. The disco was running amazing... Until when driving to school t over heated and boiled over. I pulled over and allowed it cool down.
I check for leaks and saw none.
It seems to over heat when the AC is on or under heavy load. It has been 90+ degrees here in Cali. When the temps come down in the evening it takes much more to get it to over heat. If I switch the AC off it creeps down slowly if I turn the heater on it drops pretty rapidly.
Im thinking thermostat. What else could cause this?
Thanks!!!
Old Sep 29, 2010 | 03:56 PM
NiteTrain's Avatar
air in the system will cause that but I don't think you have to bleed a d1
Old Sep 29, 2010 | 03:59 PM
rhino_e28's Avatar
No that you mention it, I have air in my heater core... I don't know how to bleed this system...
Old Sep 29, 2010 | 04:32 PM
ColoDisco's Avatar
Ohhh yes you do. I actually use a air lift to fill my D1.
Old Sep 29, 2010 | 05:05 PM
NiteTrain's Avatar
air lift? like suspension air lift?
Old Sep 29, 2010 | 05:24 PM
ColoDisco's Avatar
No..as in:
http://www.google.com/products?hl=en...ed=0CD8QrQQwAg
Mine is from Snap on.
Old Sep 29, 2010 | 06:43 PM
NiteTrain's Avatar
snap on? you must be rich!
Old Sep 29, 2010 | 07:31 PM
Spencerfitch's Avatar
Thanks!!!
Well I have never found that bleeding a coolant system EVER helped an overheating issue. But its worth a try.
With the truck cool
Drive your front right tire on a ramp. No ramp?
Go to your nearest curb. Put the TC in 4 low and drive the front right tire up onto the curb. Now put the heater on FULL BLASSSSTTTT. POP the hood. Remove the radiator PLUG before your engine temperature gets too high.
Now wait for the engine to heat up, thermostat to open and water to fill up the radiator. As the water gets higher let it overflow a little from the plug hole and get all bubbles out. Now with the water still up to the rim replace the plug.
Im probably forgetting something. And no you dont have to raise the resevoir up as high as you can.
However this is probably not the problem. And if your temperature is getting so high that you see it on the gauge its SUPER HOT.
Check and make sure your a/c e fans are working, but agian it shouldn't OVERHEAT even if these were dead.
Do you hear your fan clutch locking up when it gets hot?
Old Sep 29, 2010 | 07:40 PM
ColoDisco's Avatar
No. I am poor, I am a Audi tech.
I have seen these systems bled out through the bleed screw on the top of the radiator. Air lift just ensures it has no air pockets. I agree with spence it is rare this will cause it to overheat but it is still possible.
Old Sep 29, 2010 | 08:57 PM
rhino_e28's Avatar
I can turn the fan manual right after shutting off the motor. Bad fan clutch?
With the truck cool
