Immobilization Bypass
Old Jan 14, 2013 | 12:33 PM
1badcj8's Avatar
Eric any chance you have an updated link to that part, it no longer works? I looked around that site and did not find it, of course that does not mean its not there.
Old Jan 14, 2013 | 01:03 PM
NabisOne's Avatar
They have it if you search by the part #. Here is a link:
HARNESS 300 TDISCOVERY I KIT RANGE ROVER/DISCOVER, AMR4956 - Land Rover Parts | Rovers North
Description is for HARNESS 300 TDI KIT RANGE ROVER/DISCOVERY I
I was on the site ordering something so I thought I would take a look for it.
Old Jan 14, 2013 | 01:26 PM
1badcj8's Avatar
Yep I just found it like that also after clicking on properties for the picture in the first post. Thank you!
Need it or not I just bought it... Does any one have a picture of where it goes?
Old Jan 14, 2013 | 01:41 PM
JC Speiser's Avatar
I am still confused by this.
I have a 1997 Disco 1 SD
I have torn the dash apart using the instructions pictured here, and there is no spider unit in my dash. No plug where it used to be. No adapter. No harness to plug in to if I had it.
Maybe a 1996 model not completed till 1997?
Old Jan 14, 2013 | 03:16 PM
gprtech's Avatar
This doesn't work on 97 and later trucks; the "spider" was discontinued and the theft unit controller now does those things. It's near the passenger footwell along the right side of the heater blower. You might be able to do something similar for everything but the immobilization to the ECU, which is different. I haven't looked at the pinout or the connector.
Check the electrical troubleshooting manual for 1997.
Old Jan 14, 2013 | 11:25 PM
binvanna's Avatar
do all the late model D1's in NA have immobilizers? I haven't noticed mine
Old Jan 15, 2013 | 09:49 AM
XCELLER8's Avatar
Cool
ran into the same issue with my '98.......no where to be found....so consequently I have a brand new AMR4956 bypass plug for sale if anyone's interested.
Old Jan 15, 2013 | 10:14 PM
1badcj8's Avatar
Is this for the '96 and older? And do you mean inside the engine compartment or inside under the dash?
If you had posted this earlier I would have bought yours but its already on the way .
Old Jan 16, 2013 | 07:26 AM
gprtech's Avatar
This fits 1996 and older trucks. It's in the ceter of the dash just below where the radio mounts.
Old Jan 17, 2013 | 10:57 AM
1badcj8's Avatar
Yeah I found out a guy from work has a '95 Disco and he said he thought it is behind the radio. He thinks you have to take the radio out to get to it, is that correct? Also is it obvious where it goes, and I assume the other end then just hangs?
