Installing Lift this Friday!!
Old Nov 5, 2010 | 11:55 AM
98roverguy's Avatar
Originally Posted by Disco Mike
So have you looked to see if you have a broken spring?
Nah I was just being sarcastic. It's not quite that bad.
Old Nov 5, 2010 | 11:56 AM
98roverguy's Avatar
Originally Posted by kenk
Just a little pointer- I had trouble installing the lift springs because of space. I had to put the LR bottle jack between the axle and frame and actually jack the axle downwards. Just be careful to not overextend the brake hoses. Here is a good write-up:http://www.4x4wire.com/rover/disco/tech/ome/
I must be really slow- 'cause it took me close to 3-4 hrs. Think I spent 1/2-3/4 hr just on the front shocks and towers
Awesome. Thanks!
Old Nov 5, 2010 | 03:04 PM
AK Rover's Avatar
I started about 3 days before I planned to do my install spraying everything down with PB Blaster so I wasn't fighting rusty bolts. Even doing that I still had to cut one of the rear shock bushings off with a air chisel. Disconnecting or removing the sway bars makes it a lot easier to get the axle to move far enough to get the springs in.
Old Nov 5, 2010 | 03:29 PM
hilltoppersx's Avatar
i agree, i sprayed everything 2 nights in a row with some PB before the weekend i tackled mine. lcukily i didnt have to cut anything off although i did use a very long breaker bar.
Old Nov 5, 2010 | 03:47 PM
AK,
Now all we have to do is get you back down to Colorado and into another Disco.
Old Nov 5, 2010 | 04:53 PM
Spencerfitch's Avatar
Just finished.
With swaybars already removed.
1 hr removal
1.5 hr installation with 2 Ppl for this part.
I used 751/762 I believe. Pretty easy. And no I didn't get new shocks or extended brake lines. Yes I know exactly what this means.
I gained 2"on the front drivers side and 3" on the back driversside.
I can't see it but Even my little sister said the passengers side was higher. Pulled out the measuring tape and shure enough 3/4" lower.
I was surprised front was lower since I have stock bumper.
I love the ride NOT HARSH AT ALL
I did notice more body roll than with the old springs probably because of shocks and higher cog, and I don't have the sway bars on.
It is defiantly harder to keep straight on the highway nothing I can't live with.
No driveline vibrations
Old Nov 5, 2010 | 04:59 PM
Awesome! Glad to hear it went smoothly
Old Nov 5, 2010 | 05:06 PM
yloDiscoII's Avatar
Originally Posted by Spencerfitch
.................And no I didn't get new shocks or extended brake lines. Yes I know exactly what this means........
HAHA, I like the pre-emptive strike to the "scolding" I'm sure you'll recieve from someone for not putting in new shocks
Glad you got everything in so smoothly.....but where's the Rover ****?
Old Nov 5, 2010 | 05:14 PM
Well I'm on the interstate doing 70mph as I'm typing this. (scold me for that too) kinda hard to upload pictures from iPhone. Not impossible but I'd rather not be driving
Old Nov 5, 2010 | 09:27 PM
Ok now that the suspension has settled a little bit..
pre lift it was 31 3/4 at front and back.
Now its..
Drivers side rear 34 1/4 +2.5
Drivers side front 34 +2.25
Passenger Side Front 33 3/8 +1.6
Passenger Side Rear 33 1/2 +1.75
Out of what was SUPPOSED to be a 3" lift?
Im going to get some trim packers to level it out. And it LOOKS great. I honestly wouldn't want more, just pissed its not 3".. .
