I've been having issues identifying the right pulley here in the UK. It's a 2.5 import from Japan and it runs on 2 different belts with the A/C being ran on a separate belt than everything else. Google search engine doesnt help at all go figure. Any you fellas can help with a part number or part identification?
The other option is the smaller ERR2798 and I would call Turner to get this sorted out.
After looking at the pics again I wonder if the bushing on the front cover (ERR7146) is not the real problem.
You might want to measure the OD of that bit and compare it to the ID of the pulley bearing (I think it's 17mm).
But again I bet the guys at Turner will know what's the proper fix rather quickly.
That's all I got...Good Luck!
