Japanese import 2.5 A/C idler replacement issue
Old Aug 15, 2020 | 03:55 PM
Kalash's Avatar
3rd Gear
Default Japanese import 2.5 A/C idler replacement issue
I've been having issues identifying the right pulley here in the UK. It's a 2.5 import from Japan and it runs on 2 different belts with the A/C being ran on a separate belt than everything else. Google search engine doesnt help at all go figure. Any you fellas can help with a part number or part identification?
Old Aug 16, 2020 | 03:13 PM
OverRover's Avatar
I think you are looking for Part #: ERR7295 (superseded from ERR2798)
> https://www.ebay.com/itm/ERR7295-Land-Rover-Defender-300-Tdi-Air-Conditioning-Belt-Idler-Pulley-/291162647532
> https://rimmerbros.com/Item--i-ERR72...SABEgL4b_D_BwE
Old Aug 17, 2020 | 04:28 AM
Kalash's Avatar
3rd Gear
Thanks for the suggestion. But I tried that one. Still no luck. Just doesnt line up. I think that part is for a single serpentine belt 2.5
Old Aug 21, 2020 | 06:40 AM
OverRover's Avatar
The other option is the smaller ERR2798 and I would call Turner to get this sorted out.
After looking at the pics again I wonder if the bushing on the front cover (ERR7146) is not the real problem.
You might want to measure the OD of that bit and compare it to the ID of the pulley bearing (I think it's 17mm).
But again I bet the guys at Turner will know what's the proper fix rather quickly.
That's all I got...Good Luck!
> https://www.turnerengineering.co.uk/...ng-c2x29899063
thom_77
Feb 17, 2020 08:49 PM
rrankin
Jun 10, 2016 06:29 PM
er1c
Jan 22, 2014 11:57 PM
FlyingZebra34
Feb 5, 2013 01:20 PM
jycsalas
Apr 1, 2009 07:43 AM
