Just did camel cut AND mud flap question
In preparing for my 255/85/16 [I might order them any second or wait a month.] I did the camel cut. Ill grab some pictures if you wish. I measured 4.5CM from the bottom of the wheel well and then took a ruller and drew the line up to where seemed right. I then grabbed a hand saw and quickly gave up [I was trying to start from the top and go down.] Today I just HAD to do it, I had a friend who has one of them vibrating cutting things, or a metabo but I couldn't wait.
I heard that a sawsall wouldn't work, but its all I had so I grabbed it and went to town. Starting from the bottom was much easier, though the panel did vibrate quite a bit I used my leg to keep it somewhat still. Passenger side first finished, in the process the panel started to rip but it was only about 1cm impossible to notice and you can tell if you look really close where the paint started to burn a itty bitty bit. The drivers side went perfectly. These dont bother me, they will either be covered up by a bumper one day OR hurculined.
ANYWAYS.. While doing this mod I noticed my passenger side mud flap is ready to go. Where are some good places to order these cheap? I dont need the little mountains either.
Thats exacly what mine are made with. Work great and cheap. Most any truckstop have the mud flaps for about $25 and you can cut 4 disco flaps out of one truck mud flap. All you need is an old one for a template and a sharp razor knife.
But yeah, 4 Disco flaps out of one semi mud flap and its a hell of alot better quality too.
I am thinking of making my rears alittle longer and then using chain to hold them up like on the Dakar Rally trucks.
Thanks for the suggestions.. Ill go pick up a db antenna and mud flap at a truck stop tonight.
Heres the camel cut.. as I said.. I just used a flat edge to draw a line.. From the bottom of the wheel well [before it folds in] measure 4.5cm to the rear of the vehicle and make your mark. Then using the straight edge make a line to where the angle of the arch matches your straight edge. Makes sense?
The length of the cut if it helps anyone was 7"
