Key Fob Disco I
Heck I already have $119 towards it if you think about it.
I actually used a 2025 battery that I had brand new at the house. it fits fine and is the same 3v battery and diameter it is just slightly thinner than the 2032 so that is an alternative number for folks if they can't find the 2032 . But If I spend the money on the reprogram I will go ahead and get the 2032 battery. I fooleshly tried that programming trick which did not work. Me being hard headed again and not listening to your first post in hopes that I could magically save money but that usually never works so sorry for the repeated rant .
I feel your concern and frustration, I did the same thing you did.
The HawkEye is a Rover specific scan tool. You can put in additional key to access another model of Rover. So it will not work with Ford or Volvo. Other scan tools will work for different brand of cars but may not do the FOB programming. It’s a two edge sword!
True you would have $119 toward it but the HawkEye wouldn't work with your other brand cars. Now.....there are other scan tools that can do it but they cost more than the D1!
sigh ... . I must tell my wife that the Brits have me irritated. I actually did joke about her country being weird about their damn vehicles.
Oh well. To be honest newer cars are nice and all but there is something so satisfying about almost zero electronics and rebuilding carburetors . If this engine every goes in this thing I think a carbed engine is in order . how does a 3.0L straight six with dual side drafts sound? haha
anyways Tuesday dreaming. Thanks for all your help so far.
Ya gotta luv the mix of those 6, 12, and 24 volt cars!
The older I get the more I want simplicity, something that is simply enough to repair with less swearing in mind.
While I am not a purist I think whatever transplant you put in her to help keep her on the road is what really counts. Though I've met some hardcore Rover owners that find it very sacrilege. Like putting a Honda engine on a classic Harley Davidson...LOL
Don't forget positive ground systems either ! some of my old Farmall tractors are positive 6v ground still . Positive ground actually makes more sense than our modern way of negative ground but that's a whole different discussion
Well I was pretty much a volvo purist for the longest time then I realized that its all just mechanical crap and none of these vehicles have a sole or any type of conscience so I am going to enjoy what I love and combined it. Like putting a v8 in a volvo 240. There is no replacement for displacement and I want the smooth power of a v8 in the awesome handling and comfort of my 240 ... so it makes sense to combine the two right? The Rover v8 has never been a wonderful engine . It is a buick engine that buick didn't run for long as I am sure you know . The owners of land rovers when they were new probably didn't do proper maintenance on them like use only synthetic oils and change them every 3-5k and they probably didn't use good antifreeze rated for aluminum . These are things that killed the buick engine in the first place and buick knew this so they gave up on it. Granted the all aluminum engine was a great idea , people are just flat out ignorant to how automobiles work and so they abuse and destroy them. Now that our oil and coolant specs are up to par we should be able to make these all aluminum engines last a lot longer so I will try my best to keep this thing running the way it is supposed to for as long as I possibly can. However I have no reservations to transplanting a driveline.
Here, Here!
Behold!
Preaching to the choir!
LOL
I agree with everything you said. You can combine the tech to make it better than at the factory that do it. the only reason the factory didn't may have been because of copyright and patents laws. I enjoy seeing different stuff that just works. Combine the best of all of it and most important have fun doing it!
Behold!
LOL
Hello Junior Member!
A used two button FOB can be had on ebay from time to time.
You'll have to take it to the dealer for programing. Or if you have access to a HawkEye 5070 scan tool you can program the KOB to your cars system. There are other scan tools that can do the programming but all the scan tools are hundreds of dollars.
The 95 D1 can be programmed without a scan tool.
The Toyota Rav4 keys can be cut to work with our cars.
