Kick down cable
Location: Oklahoma; where the winds come rolling down the plains.
on
It is very difficult/impossible to re-fit the cable with the valve body in situe, if you do remove the valve body first mark the location front/back as the correct position is critical. Only remove the M6 bolts, ie the ones with the larger heads. DO NOT REMOVE ANY M5 BOLT.
When re-fitted it is possible to move the change points a little, start point is to set the cable so you get 'forced- kickdown' as the throttle presses into the carpet. Then loosen the cable to shift earlier or tighten to shift later, no more than 2 or 3 mm each way. The transmission end needs to be attached to a cam inside the transmission. The valve body needs to be removed.
on
Just out of curiosity I did a search on "kickdown cable" and found this thread:
https://landroverforums.com/forum/di...trouble-15358/
Might be worth checking it out before you tear into the tranny.
Danny, it does address it, but very vaguely. IE does not say to remove the valve body but as I see it the cable comes in through the top of the transmission housing. It is hard to even see the connecting point. This clued me into the fact there might be more to this than just taking off the pan and filter, plus anyone who has done one can give me simple instructions rather than me deciphering what the Queen intended!
![Wink](https://landroverforums.com/forum/images/smilies/Uh2vXQr.png)
I am sure that my cable is bad as it is broken where the threaded section attaches to the bracket prior to reaching the throttle body. I know this as I have it rigged to work right now. Looks like it is going to have to wait until after my camping trip into the mountains next week. I will take pics and try and document this for those in need next time.
