L.E.D rear lamp assembly
Has anyone found some after market ones to replace these crappy ones, every Disco I've seen at the junk the right rear lamp is always jacked up.
I'm sick of those lights, they're a pain to remove and mess with .
If new ones cost near $100 each, I'm fine with payin 150 if I don't have to stick my hand in there again.
Right now I got it rigged with some foil...
What exactly is the problem with them??? Mine are just fine and dandy and have been for years. And access to replace the bulbs is actually quite easy compared to the D2's. You could always install LED bulbs. But the problem with them is they can be very directional and often need some sort of optic to focus or diffuse the beam.
https://landroverforums.com/forum/di...y-issue-46369/
