Land rover discovery 1 1997 Radio install issues HELP!!!
Old Nov 11, 2017 | 03:27 PM
Christian Vogus's Avatar
Default Land rover discovery 1 1997 Radio install issues HELP!!!
Okay so i bought the adapter i need to install a aftermarket radio into my rover but im having some trouble (i just ordered a different adapter in hopes of that working) but i cant get the radio to work and i dont have the time or money to rewire the entire system im worried my radio system is grounded out weird or something because if i take a multi meter and touch it to left radio (-)or(+) then on the radio 12v power plug i get a voltage reading... is that okay or am i going to have to take my dash out and gut the car until i find a problem???? CAN ANYONE HELP??? this was supposed to be easy.
Old Nov 11, 2017 | 03:33 PM
here is a picture of the plugs for the radio
Attached Thumbnails Land rover discovery 1 1997 Radio install issues HELP!!!-20171111_162834.jpg   Land rover discovery 1 1997 Radio install issues HELP!!!-20171111_162911.jpg
Old Nov 11, 2017 | 05:12 PM
dicksoutforharambe's Avatar
I put an after market in mine it was a big pain in the ****. Put about 60 hours into it and cut of all the harnesses because nothing fit. So I just ended up rewinding the whole thing. I know this doesn't help but I wish you luck.
Old Nov 12, 2017 | 11:33 AM
Toran's Avatar
What harness did you get?
I used a Metra 70-9400 Radio Wire Harness without any issues.
Old Nov 12, 2017 | 12:46 PM
I don't remember which harness it was. I bought it from crutchfield. I tried so many different things and when I did get it to work I was getting interference from the amp in the passenger footwell. I just ended up running all new wires, speakers, subwoofer and amplifier. Now it sounds great
Old Nov 14, 2017 | 02:16 PM
ROB99DISCOSD's Avatar
Radio re-do’s are a G damn nightmare. I basically required my whole set up too. Just a nightmare....
Old Nov 14, 2017 | 04:18 PM
bowser's Avatar
you can just ground the head unit to any ground you want (or make your own) to if that's your issue. there's a cigarette lighter right below that wouldn't be too hard to get to. if you have 12v constant and acc you should be good to go. I would run new speaker wire though when you have time and bypass the amp. you're not going to be able to integrate it so just bite the bullet and bypass. you'll have plenty of power out of the aftermarket head unit anyway. plus speaker wire is cheap
RoverGuyZ
Jan 11, 2026 01:00 PM
dogstarsix75
Apr 24, 2020 01:33 PM
SamWalker
May 15, 2014 06:27 AM
sickws6
Jan 8, 2012 12:48 AM
s928s
Audio/Visual Electronics
Oct 28, 2008 02:54 PM
