Landy cut out
Old Jun 9, 2015 | 09:18 AM
Kobus van Eeden's Avatar
Angry Landy cut out
Hi every body
This one is for the clever one's. I have a Land Rover Discovery 1 v8i 1996, every few kilometer's the landy cuts out, then wait a few minutes she start's up again, I have tested the voltage at the petrol pump which's is 11.1, also the white and purple wire coming from the fuel pump into the relay of the petrol pump which's is progressively climbing up to 28 volts and cuts out. I have replaced the petrol pump the coil and the petrol pump relay, I have check the negative wires from the battery and the coil. I have even strip the dash to get to the spider black box which's did have dry joints, I have fix all of that, obviously I have missed something. Is there anybody that can help me.
Thank you
Kobus
Old Jun 9, 2015 | 10:05 AM
drowssap's Avatar
have you replaced the fuel filter?
Old Jun 9, 2015 | 10:27 AM
TOM R's Avatar
crank sensor is getting hot, needs sheilding or repair to wiring or both
Old Jun 9, 2015 | 11:01 AM
Hallo drowssap, yes I did replaced the fuel filter
Old Jun 9, 2015 | 11:03 AM
Hallo Tomr, I will look were the crank sensor is and maybe that is the problem, THX
ANY IDEE OF WHERE THE CRANK SENSOR IS I HAVE LOOK IN THE MANUAL THE BOOK DOES NOT MENSION IT, THX
Old Jun 9, 2015 | 11:21 AM
TOM R's Avatar
it is on the left side of the engine where the engine meets the transmission where exhaust can heat it up
since you say drive a few km, shuts off and restarts after a cool down makes sense this sensor is getting hot or wiring is damaged, common issue
hope thats your problem since it is an easy fix
Old Jun 9, 2015 | 11:45 AM
WaltNYC's Avatar
Same as a D2
Old Jun 9, 2015 | 12:21 PM
TOM R's Avatar
location is the same, sensor is similar that,gives you a good idea, my d1 does not have that metal cover
Old Jun 10, 2015 | 11:35 AM
Hi Tom R
Call me blind but I don't see the crankshaft sensor in the location you mentioned, I did saw something similar to that at the side of the automatic gearbox when I disconnect that sensor the landy switches on but that is about it.
Old Jun 10, 2015 | 02:15 PM
TOM R's Avatar
starter is on one side of the engine crank sensor is on the oppposite side same location
