leaking rear
My back rear has decided to start leaking first pass side for a few weeks now drivers side
Looks like a lot, other then clogged vent line any other suggestions?
I got bearings in route tried to order the double seals but someone does not like answering their phone or returning voicemail
Unbolted the vent from rear blew out line and bolt saw no obstruction,removed fill plug blew back through line with line bolted up still fine no idea what's going on here, definitely gear oil not brake fluid
check the gaskets on the drive flanges. Either there or the hub seals are the only places it can leak besides the plug. RTC3511s can be had almost anywhere that sells rover parts. Order extra and keep a few spares.
echoes_and_fractals
Aug 27, 2006 11:11 AM
