Leaky Roof...
Hello guys and gals:
So I've got a 98 D1. After a week of heavy rains, it's leaking in the following places:
- Around the rear sunroof controls.
- Near the rear hatch hinge
- The driver's side a-pillar
Yes, pull the headliner (now would be a good time to install new material. There are cheap option on eBay.
Rear sunroof likely needs a new gasket as does the rear cargo door. Seek out a gasket from a D2 for the door, they are better.
The A pillar could very well be a leaky windshield. That is quite a bit more tricky to deal with depending on your findings
I like the youtube Britannica Restorations videos, very funny and educational. He simply caulks the Rover sun roofs because "they all leak". I got rid of an annoying high speed whistle when I caulked mine. I used Stick and Peel caulk in case I changed my mind, but I'm not going to change my mind, so a good permanent weather and UV resistant clear silicon caulk can be used. I spent a lot of time trying to fix the sun roofs before I sealed them up.
Drivers A pillar could be coming from the sun roof too, that's where the drain tube runs down. Bear Mach Trailfitter videos are also very educational, but not quite as hilarious as Britannica. Sun roof leaking also causes the headliners foam to rot and the cloth to fall down. Good luck patching things up.
What would you recommend to use as a sealant?
I believe there have been good results with black Permatex RTV for sunroof. These sunroofs were a really bad design and they all leak because the gaskets and glass and housing warp and fail over time. Causing gaps which let water in. I am going to seal mine one day soon permanently but for now I just don't drive it when it rains. It is a second vehicle for me.
You can also use the permatex to fill any spots where the rain rail meet the rubber gasket up by the drivers and passengers front a pillar. A lot of times there is an opening or a gap that allows water in and it will run down inside.
Water is a threat to the D1's because it causes mold and rot. Take your time, find the openings and apply according.
I found a DAP product at Home Depot I bought but haven't applied yet. It's called UltraClear Flexible All Purpose Waterproof Sealant made for roofing, windows, and doors. It can be applied to wet and cold surfaces. The key will be surface prep to clean the surfaces really well. I used compressed air and Windex and a bunch of rags to muck out all the dirt.
