leaning landrover
leaning landrover
I have a 1996 landrover SE7 with 140000 on road miles. The front has two different coil springs which makes it lean towards the passenger side. The coils are closer together on driver side than the other. Really weird. No broken springs. someone HELP PLEASE. thanks. Shawn
Land Rover springs are handed. The driver and passenger side are different on purpose, and the springs are different for RHD versus LHD. Almost all aftermarket springs in the North American market are not handed. OME, which originates in Australia where RHD prevails can be handed. Maybe with RHD it makes more of a difference.
Oftentimes people with leaning rovers find out it's not because of the springs, but because of bent anti-sway bars, failed bushings, or other broken items. Also keep in mind that the rear suspension greatly affects the attitude of the front corners on which it pushes.
Both good points.... They are handed (Aren't they Brett?) Why they are is a mystery to me... Is there really that much bias from one side to the other? Or are they figuring in the weight of the driver?
I was changing springs for performance and lift; which is why I bought the Disco to begin with (i.e. I intended this to be a "wheeler", not a daily driver.")
When I took out the springs and stood them up on the floor, the front passenger spring was bent almost 45 degrees... I thought it was odd that the one spring would fail like that unless it was involved in a pretty good accident (no other evidence of that). In my experience with past (not rover) vehicles, pairs of springs or other components typically failed at about the same rate.
Also some springs may appear to "bend" on one side. On my brand new 3" RTE fronts, the passenger spring looked like it was bowing towards the front and indeed it was. The solution was to spin the spring 180*. It has to do with how the spring is cut.The gapped part of the bottom of the spring was facing forward. That combined with the forward slant of the lower spring perch(due to the axle dropping) gave the spring a forward bow, like this ), when looking at the profile from the passenger side.
I spun it 180* along with my Ballistic Fab lower spring retainer and now it looks like this: l
Their picture is jacked up but the drawing shows the measurements.
