Lift Kit Recommendations
4 inches is just to much for these trucks without having other issues that you likely don't want. What exactly is your intended use? Rock crawling? I believe 3 inches of lift with the right size tire will more than get you where you want to go without having to change other steering components, etc. You CAN do 4 inches but others here will need to chime in and give you advice on what other components you will need to alter as well. I would recommend OME springs/steering stabilizer and Bilstein shocks.
Thank you, and I agree, 4" suspension lift is too much, I think I was thinking 4" all together with the lift and tires. I appreciate your advice.I need to do a whole overhaul, it starts but has no brakes, and also overheats at highway temps. I think this little 4.0L may have a head gasket issue that needs looking at first...
miron
05-30-2019 06:38 PM
