Want a lift kit disco 2
Old Mar 26, 2011 | 10:50 PM
Sunny side auto's Avatar
Default Want a lift kit disco 2
What's a good lift kit and how high can I go .
Old Mar 27, 2011 | 07:10 AM
jeffh's Avatar
Old Man Emu, it is what I have and what most on here will talk about.. call lucky8 and talk to them. How high depends on what you are trying to do with your truck. They also carry terra firma. The higher ou go the more work you will need to do..i.e. brake lines, prop shafts etc. etc. good luck and have fun.
Old Mar 27, 2011 | 08:33 PM
dcarr1971's Avatar
Terra Firma makes a pretty good kit too...as previously said, the guys at L8 can point you in the right direction...
Old Mar 27, 2011 | 11:51 PM
I really want to run 32 inch tires .
Old Mar 28, 2011 | 12:17 AM
DiscoRover007's Avatar
I run 32's on the terrafirma 2 inch lift. You'll have to get into a lot of crap if you want a 5 inch lift.
Old Mar 28, 2011 | 10:47 AM
yloDiscoII's Avatar
I'm running the medium 2" OME kit with 32"s (265/75's). I was considering a 3" but didn't want to spend any more money to correct driveline angles, extend brake lines, etc,...
2011-03-20_13-55-30_15.jpg?t=1301327331
Old Mar 28, 2011 | 12:36 PM
Some one give me L8 number or have him call me at 5033186293. Thanks
Old Mar 28, 2011 | 01:13 PM
hilltoppersx's Avatar
Lucky8 LLC 716-898-8153
Old Mar 28, 2011 | 03:27 PM
yloDiscoII's Avatar
You could try giving Columbia Rovers a call as they are local for you. They are a couple dollars cheaper and they are in Portland (as assume you are in Portland based on your phone #) so you could go pick it up.
www.Columbiarovers.com
635 NW 16th Ave
Portland, Oregon 97209
503.227.3766
Last edited by yloDiscoII; Mar 28, 2011 at 03:31 PM. Reason: posted the wrong address
Old Apr 15, 2011 | 03:41 PM
Ranger Moore's Avatar
6th Gear
Default New Disco owner
I have read numerous posts, I like this thread a lot and I believe I am in the same boat. I have a sagging rear end on a new to me 2000 disco that I would like to convert to coils. Shouldn't I just redo the whole suspension (all four) woth coils and shocks? I sure could use 2" more lift to get me over rocks at the so called boat ramp. Should I just do the rear coils and add spacers to all four for the lift. What happens to the air compressor after all fo this is modified? Surely you all don't just leave it under the dtruck wired up? Is there anyway to use it as a tire inflator (showing how new I am). How does one disconnect the power to said device including the leveling doo dads. Also, what is the lug spacing on the rims so that I can start looking for aftermarket rims on craig's. Are there any other vehicles that match this lug pattern?
