Lift kit for sale to make my tires fit?
Old Apr 16, 2012 | 04:25 PM
  #61
Jake1996D1's Avatar
Originally Posted by filbs
rabble rabble rabble
Keep reading, you may learn something
Old Apr 16, 2012 | 05:10 PM
  #62
calebbo's Avatar
Originally Posted by fishEH
Stop wasting peoples time. READ the responses then reply accordingly. Nobody gives a crap about Crutchfield.
WHAT TIRE SIZE DO YOU WANT TO FIT?
WHAT DO YOU WANT TO USE YOUR TRUCK FOR/BE ABLE TO DO WITH IT?
Don't get mad at me, I'm not even the original poster lol. He disappeared actually.. Must have ran when the chaos broke loose haha
Old Apr 16, 2012 | 08:57 PM
  #63
filbs's Avatar
I will continue to read and have already learned tons...... that wasnt directed at anyone . I just chuckle when you guys get all bent out of shape... I spend hours a day picking through the wisdom of the forum......
Old Apr 16, 2012 | 09:22 PM
  #64
Originally Posted by calebbo
I believe most people say Medium is a good choice if you want to do some mild off-roading. But if you ever plan on getting front or rear aftermarket bumpers, roof rack, etc etc you get the picture.. then go for the HD.
The type of spring you choose, medium or heavy duty, depends on the amount of weight you want to carry.
Terrafirma Suspension - Coil Springs Accessories for Land Rover Vehicles
Old Apr 17, 2012 | 11:06 AM
  #65
Chris-bob's Avatar
Sorry my fault I apologize I have never seen that add on. You wont need it if you buy shocks from Justin cause they come valved depending on your rover
And FWIW I had Rancho 9 way adjustables - it's a pain in the *** to adjust all of your shocks manually every time you go off road/on road
Yeah, I hated the Rancho setup on my Heep. Never did seem to get the right ride. Having Fox with replaceable valving would have been the way to go. That, and I kept breaking the Ranchos(blowing seals). And I'm sure they were the correct size.
Do you know what valve Fox uses for LR D1 application?
Old Apr 17, 2012 | 11:26 AM
  #66
Jake1996D1's Avatar
Depends on where you get them I dont know the factory spec but most guys have around 85/95 front 90/100 rear. D2's are different. I'm running 95/100 in the front with the 3-link which may sound crazy but the 3 link makes everything so much softer. Worked out good
Old Apr 17, 2012 | 09:30 PM
  #67
gulfcoastgorilla's Avatar
Original poster here! Just to let everyone know I put a 1.5 inch suspension lift of the springs and the 265 75 16 tires fit beautiful. Now if only that knock sensor comes in the mail I'll be ready to go
Old Apr 18, 2012 | 12:16 AM
  #68
fishEH's Avatar
1.5", OME I take it? What shocks?
Old Apr 18, 2012 | 10:07 AM
  #69
I meant to say that I used the suspension spacers 1.5 inch. This forum doesn't seem to like them but in jeep forums it's seen as a good upgrade
Old Apr 18, 2012 | 10:50 AM
  #70
fishEH's Avatar
Spacers are really only good for one thing; fitting bigger tires. Spacers won't increase your load carrying capability or replace your worn out springs. And unless you went with longer shocks or moved the stock shock mounts down you will have very little downtavel.
Otherwise spacers are a cheap and easy way to get started. If I were you my next move would be to get longer shocks and make a set of swaybar disconnects. With those thongs you should go pretty far. Also, there is a "cheap bastard" lift where you replace the rears with some Jeep springs(I forget which ones) and then move the stock rear springs to the front. Cost for that maybe $50.
