Lift and tire size suggestions
Old Feb 28, 2015 | 11:14 AM
ocdisco74's Avatar
7th Gear
Default Lift and tire size suggestions
I'm getting ready to install my heavy duty OME lift on my 97 D1 and wanted to see what kinds of tire size recommendations you guys might have. I'm considering 235 85R16.
Let me know what you think.
Old Feb 28, 2015 | 11:30 AM
calebbo's Avatar
Thats what I use exactly BFG AT. Love it.
Old Feb 28, 2015 | 07:56 PM
TOM R's Avatar
I have OME HD 2" and run 245/75/16 , I have drop away articulation no rubbing
Old Feb 28, 2015 | 09:46 PM
fishEH's Avatar
235/85/16 is perfect.
Old Mar 1, 2015 | 07:43 AM
TOM R's Avatar
Fish those taller then stock or just wider? Mine are taller an narrow I guess
Old Mar 1, 2015 | 09:17 AM
calebbo's Avatar
235/85/16 is taller but same width as stock
Old Mar 1, 2015 | 09:22 AM
Fenix's Avatar
I have a 2 inch Terrafirma lift and run that size and I'm really happy with it so far. You will probably need to do a camel cut on the rear quarter panels and adjust your steering stops to avoid rubbing. Both really easy to do.
I use Goodyear Duratracs. I got 5 tires for around $850 mount and balanced.
Old Mar 1, 2015 | 09:29 AM
fishEH's Avatar
I don't remember what stock is anymore, LOL.
The first number is always the width, in mm's. So your 245 is 10mm wider than 235's.
The second number is the aspect ratio. The percentage of the width that the sidewall is tall. 235x.85= 199.75mm tall sidewall.
Old Mar 1, 2015 | 10:46 PM
calebbo's Avatar
235/70/16 is stock
Old Mar 2, 2015 | 08:45 AM
TDRover's Avatar
I also run 245/75/16 on a 2in lift
