Losing coolant
Losing coolant
Out on the trails today and I was heading up a muddy hill, Ended up using a bit too much power and the coolant reservoir tank let loose. Temps got warm and dumped most of the coolant. Once it cooled down, I refilled and it seems to be running at normal temps. BUT.. the tank has developed a pretty steady drip and I am guessing the seam may have separated.
Anyone have a tank laying around?? I have been watching the temp and it was normal for the 12 mile drive home so I think the motor is OK...
1997 Discovery 1 with the 4.0 motor
Atlantic British has the genuine ones for 75 bucks and cheaper for the black aftermarket ones. Otherwise I would think a local wrecker is best bit. But using tooo much power should not cause overheating enough to empty coolant reservoir. I would start looking into why your cooling system can't keep up before something bad happens. At least if it overheated to overflow it doesn't mean it was exhaust gasses in the coolant for sure.
