Lots of drivetrain problems
Old Sep 6, 2012 | 10:24 AM
deer4011's Avatar
Default Lots of drivetrain problems
So I have a 99 disco 1 and it started to make a rattling noise from what sounded like the frond drive shaft so instinctively I changed out the u joints. But I still am getting the same popping noises from the same area. And my transmission whines really bad and it has a slight grinding noise while it's in gear. What are your thoughts
Old Sep 6, 2012 | 10:46 AM
ValveCoverGasket's Avatar
my thoughts? it sounds like its time for a trans rebuild...
Old Sep 6, 2012 | 10:56 AM
deer4011's Avatar
Should I try to go through the fluid and filter routine first
Old Sep 6, 2012 | 07:57 PM
Have you checked the fluid level in the transfer case?
Old Sep 7, 2012 | 07:49 AM
deer4011's Avatar
I was going to change the oil in it today with some 85w-140 along with both diffs so I'll see how that goes
Old Sep 7, 2012 | 08:14 PM
Danny Lee 97 Disco's Avatar
There is an inspection plate on the t/c. I would pull it and see what the innards look like.
Old Sep 8, 2012 | 08:18 AM
deer4011's Avatar
Will do hope fully is should get it done by today. But on another note I'm still getting a popping/rattling noise when I accelerate like its bad u joints even though I replaced them. Freaking rovers.
Old Sep 8, 2012 | 12:58 PM
When were the wheel bearings last packed or replaced? If not recently or unknown, I would pursue that route. Jack up the front and rotate the wheel by hand. See if you feel or hear anything.
mdt9987
Mar 23, 2019 06:03 PM
pedro_malo
Jan 14, 2012 08:30 AM
aircraftguy
Jul 16, 2009 12:50 PM
phidelt583
Dec 11, 2008 08:41 AM
blair
Jun 19, 2008 01:13 PM
