Lucas hub oil for swivels?
Old Sep 14, 2010 | 07:10 PM
greg409's Avatar
Default Lucas hub oil for swivels?
I've ordered and am going to try lucas hub oil in my swivels.
It's (by all I've read) a severe duty synthetic heavy oil that clings to metal surfaces to protect even in the event of seal failure. (big truck hub bearings)
It also claims to help stop leaks (don't they all)
I've contacted Lucas in Canada for a little input (will it mix with moly-based grease and gear lube? - OK for cv joints, etc.)
I'll post as necessary
luck,greg
Old Sep 14, 2010 | 08:34 PM
Let us know what they say and how much it is with shipping.
Old Sep 14, 2010 | 08:40 PM
Danny Lee 97 Disco's Avatar
Bless you Greg, I was getting a little concerned with my swivels after all the recent discussion. I'll be interested in your findings.
Old Sep 15, 2010 | 08:14 PM
greg409's Avatar
Sorry, it's not synthetic - bad boy
It's about $8/qt. (32oz.) $5 ship (Summit racing, online)
The gen mngr in canada, "Alan Newstead", emailed back that it plays nice with grease & gear oils, but will reduce the NLGI grade of grease & make it softer.
One shot's soft already, like mayonaise
Since he didn't throw up red flags, I'll try it.
luck,greg
Old Sep 16, 2010 | 06:31 AM
Long Haul's Avatar
Thats what I was going to put in my swivals last time I changed them. But the truck stop was out. I use that stuff in my trailer hubs that leak i'll vouch that that stuff does stop leaks pretty good. The only down side to it is its thick as molases. I always warm it up so its easier to pour. FWIW most truck stops usually carry it if you have any local.
Old Sep 16, 2010 | 08:48 AM
okdiscoguy's Avatar
I put that in when I first got mine. Didn't leak. I took everything apart the put new seals and bearings in my swivels and changed to the RP concoction. Everything looked ok when taking apart.
Old Sep 16, 2010 | 12:06 PM
NiteTrain's Avatar
how much do the swivels hold? it might be cheaper to just use the LR one shot packs or 00 grease
Old Sep 16, 2010 | 09:51 PM
greg409's Avatar
According to the rave - 3/4 of a pint - ea. (one tube of one-shot in ea.)
This is a qt. will do (2) with a little left over - I'm going to thro' in a pint in ea. probably
This was $13 shipped to me, but I'll find it locally for around $8 I think.
I checked it today, has the consistancy of honey @ room temp
luck,greg
Old Sep 17, 2010 | 03:15 PM
NiteTrain's Avatar
I put some in my DIIs rear diff a few years ago, it was leaking. It's stopped leaking now but I also changed the gear oil with a higher weight and replaced O-rings at the same time so i'm not sure if the hub oil did the trick or not. It was hard to find locally I think I had to order online.
Lord Wert
Dec 1, 2012 08:22 PM
mx468
Nov 28, 2012 09:00 PM
aarongregor
Oct 1, 2012 02:20 PM
slanginsanjuan
Jun 10, 2012 02:37 AM
malmberg
Nov 3, 2008 06:04 PM
