major junk yard score
Old 04-21-2013 | 08:43 PM
TOM R's Avatar
Default major junk yard score
made out great today at a u pull yard I goto disco 1 got the bug hubcap for the steel spare, had brand new lines for the ps pump got them, new trans lines got them ( all 3 ), copper radiator, lock actuator, latch assembly, outer door handle all for the rear pass side door $45
and I am going back tommorow cause it has a 2" lift with bilstien shocks no idea what brand springs but they look shiney new and black looks like they have marks with colored paint does that give a clue to the brand springs? the y still have the paper mfg stickers buy the ink is gone
they said $65 for the springs and shocks guess i am canceling my backordered lift
figuring we will unbolt everything and have them lift it so the springs fall off
Old 04-21-2013 | 09:18 PM
Scope's Avatar
Good score!
Old 04-21-2013 | 09:28 PM
CUpgt's Avatar
Wow, I scored a copper radiator,window motor, fuel pump harness, a MAF and some other small stuff for 150 today. No sweet suspension or anything. Really wish I had snagged the TPS of the two they had.
Old 04-21-2013 | 09:46 PM
TOM R's Avatar
yeah when in va i always goto this yard and have scored big before; sensors, facotry rubber floor mats and cargo liner, running boards, mudflaps, misc interior stuff, new brake calipers and lines,etc and super cheap just sucks they pull the tanks cause i would like a nicer fuel sender, and all the discos are rust free
Old 04-21-2013 | 09:48 PM
Rover_Hokie's Avatar
Where are you in NE Va.?
Old 04-21-2013 | 09:53 PM
TOM R's Avatar
westmoreland county it is on the potomac near 301, when I am down here
Old 04-21-2013 | 09:54 PM
CUpgt's Avatar
Some jackass pulled the fuel pump on the 98 they had, broke the sending unit and took the pump and left the broken sending unit on the ground.
Old 04-22-2013 | 07:48 PM
TOM R's Avatar
ok can someone help me id these springs? they are black and are marked with color paint, the fronts are like blue/yellow and blue/red back are both marked yellow/blue/pink ? or something like that I see no stamped markings and the paper tags have all the writing washed off
I also lost one of the bushings for the top one the rear bilstien shocks i hope a stock one will fit
Old 04-22-2013 | 08:04 PM
They are ARB springs, the colors are to tell you which corner they go on as Rover uses corner specific springs.
Old 04-22-2013 | 09:39 PM
TOM R's Avatar
wow so then I got a real good deal then, may not be a lift but the rover i took em from sat waay higher then mine
Quick Reply: major junk yard score
