MJ 98 50th aniv model
Thanks all, had to make a dash to Stuart Fl Thursday back now 12:13 am Saturday only 1056 miles RT. Drove the Back Breaker 2010 Dodge Ram 1500 Hemi.
I FOUND a Brush guard for it on the parts truck but need the correct lights.
HOPE to work on it today and get the maintenance done so I can road test it with the stat in it. No idea if it has one now but will find out QUICK.
Will put our Rejuvinator on the seats and let it SOAK for the day to get the leather soft so I can touch up any bad spots with dye. Did not see any BUT when you put on the Rejuvinator you see a LOT since you do that by hand.
Looks Great. From the side however, it does appear to have the same condition that all Discoveries eventually get when the original springs wear out. That being that they sag. How much clearance do you have between the road and the bottom of the running boards?
It may be fine for street use, but if you do get it offroad, that can quickly turn a fun run into the shock when you rip off a low hanging plastic front airdam or side running board. That happened on my first trail encounter with my Disco. I did not realize how badly mine was sagging until I parked between two other Discoveries at our next monthly gathering.
Mine, Leatherique, own the company. Need to advertise on this forum since we will be doing a full interior spruce up.
