is my discovery weaker than it should be....
Old Mar 27, 2012 | 04:54 PM
Nicholas Rowland Ellis's Avatar
Default is my discovery weaker than it should be....
Im looking after my dads 95 300 tdi discovery right.... it seems to run fine, no obvious symptoms of bad motor, i can hear the turbo working under loads sounds normal i think. but it feels a little weak on hills......
for comparison, I have a 86 hilux with a 2.8 litre natural aspirated diesel. its supposed to have 90 horsepower and about 150 foot pounds of torque. on the hill at my house I can go as slow as I like, and feels like it want to keep accelerating. that same hill i need to get a run up on the disco, not much but it does start losing power at the top.
the 300 tdi is supposed to have 110 horsepower and 250 ft/pounds torque. now I know that the disco is a fair bit heavier. hilux is 1400 kilos, and disco is between 2 ton and 2200 kilos, but the disco motor has so much more torque..... Shouldnt it be able to do the hill better than my hilux?
Old Mar 27, 2012 | 08:56 PM
Its not about power in that situation as much as it is about weight and gear ratios.
Old Mar 27, 2012 | 09:19 PM
thats true but over it feels like its really weak. it just chokes on hills. if it was a ratio problem wouldnt i be able to get a run up and then have some more power?
Old Mar 27, 2012 | 09:53 PM
I have zero experience with the Rover diesel, but all Rovers are slow and feel sluggish.
A dirty air filter or fuel filter can have a effect on power.
But keep in mind your Rover weighs almost twice as much as your Toyota and has not much more power, for it to really feel equal it would need twice as much power as the Toyota.
Old Mar 28, 2012 | 07:52 PM
my mechanic cranked up the injection on the pump, and wow, what a difference.... thing takes off now. revs like a champ to.
tested the hill, its like the toyota now, maybe feels a little heavier of course.
so if your 300 tdi feels slugish try adjusting the injection pump
Old Mar 28, 2012 | 07:55 PM
Jake1996D1's Avatar
That massive black cloud you're leaving behind now is probably not good for the environment
Old Mar 28, 2012 | 08:06 PM
so is an oil spill in the gulf. If you can get away with that then I hink a little smoke wont hurt haha.
Better yet are those dodge cummins..... the amount of smoke those THINGS below out.......
Old Mar 28, 2012 | 08:09 PM
A diesel that is tuned correctly will not spew black smoke, but one that has been tuned or turned up or "chipped" will.
Umm Excuse me mam....Do you smoke? - YouTube
Old Mar 28, 2012 | 08:21 PM
Jake1996D1's Avatar
that was awesome and she had really nice ****..
she smokes she ****s
Old Mar 28, 2012 | 08:26 PM
lolz that was awesome.
the rover lets out a little smoke but not nearly that much, hilux lets out allot more
johnkbl
Sep 28, 2010 03:39 PM
99LRDisc
Jun 26, 2008 07:56 PM
mlfore
Apr 8, 2008 03:38 PM
DrDrisk
Off Topic
Feb 10, 2008 11:19 AM
meineke495
Nov 27, 2007 06:49 AM
