need computer info please
Old Dec 15, 2017 | 10:13 PM
rickroverover's Avatar
Default need computer info please
For troubleshooting I have acquired a MFU and the matching ECU.
Considering how hard it is to get to the back of that fuse box...
I have seen quick comments that these ECU's will allow 2 starts in a unmatched vehicle b4 they will require testbook matching.
1) Is this true?
2) does that mean 2 starts for the life of the ecu? as in must be matched to it's original vehicle and MFU b4 it can ever be used as a test unit again?
3) the ECU in my troubled D1 has numbers that do not match many ECU's I have seen in pic's and the other 2 spares I have. Also shows to be a refab (painted). Does anyone have a definitive source for ECU information? Like vin applications, dates of manufacture etc?
Thanks all y'all
Old Dec 16, 2017 | 07:19 AM
ihscouts's Avatar
MFU - Multifunction Unit or alarm? The multifunction unit is the fuel pump/ignition relay, it doesn't require pairing. The alarm (AS10) and ECU does in many cases. I can't comment on the two starts before dead, they worked or didn't work right out of the box for me. A friend of mine had successfully swapped ECU's without needing pairing, he had an AEL 97 produced from mid 97 onward. I had an early 97 without AEL. That seems to be one of the factors, having a later 97 but as it's a Rover I wouldn't say that's an absolute.... Paul Grant would be the hands on guy, send him a PM.
justryan
Defender
Mar 18, 2016 08:57 AM
cheqbay1997
Jun 11, 2014 10:24 AM
cheqbay1997
May 11, 2014 12:03 PM
Ezequiel
Jun 25, 2010 06:48 AM
neilp
Jan 3, 2005 04:47 AM
