need fuel sender gasket
Old Sep 13, 2014 | 10:17 AM
TOM R's Avatar
Default need fuel sender gasket
Just filled up and fuel all over pulled sender access and fuel on top of tank, pulled sender and the tank seal is split need one asap, thought it felt a little non pliable when it was apart recently
Old Sep 13, 2014 | 07:55 PM
TOM R's Avatar
Found I have a spare in my storage
Old Sep 13, 2014 | 08:52 PM
ihscouts's Avatar
Lube it like.....well you know, you only get one more chance.......
You have any CIP? Works like a charm and softens rubber like no other.
Old Sep 14, 2014 | 12:21 AM
jimvw57's Avatar
Whatever you do, do NOT use a silicone based form a gasket or any sealant that is not rated for gas immersion. they tend to disintegrate and plug fuel filters, and small openings.
Old Sep 14, 2014 | 02:32 AM
Dach Savage's Avatar
Ok so what is CIP and where can one get it? Dach.
Old Sep 14, 2014 | 07:11 AM
ihscouts's Avatar
CIP - CIP Lube
Petrol Gel - About Petrol-Gel
Both are excellent for rubber gaskets.
Old Sep 14, 2014 | 08:03 AM
TOM R's Avatar
Used spray lube, think wd40 is all I had handy,guess I need to grease it
Old Sep 14, 2014 | 11:12 AM
ihscouts's Avatar
Vaseline works in a pinch.
Old Sep 14, 2014 | 09:34 PM
TOM R's Avatar
All fixed
Old Sep 15, 2014 | 03:12 PM
Thanks for the link. Odorless and tasteless eh? Sounds like it might be good for all kinds of uses... Yes Vaseline is pretty good too, WD-40 will actually destroy rubber in fairly short order. I am going to order a tube of the CIP to keep in my toolbox. Hmm, maybe I better order two...
