Need help asap!
I just bought a 1998 Disco 1 with a 4.0 engine and 165k miles. I changed the oil for the first time today. I used 5 quarts of castrol 5w30 oil and a Napa gold oil filter. after I was done I went about a mile down the road and the oil light came on. after about 10 miles the check engine light came on and I began to lose engine power and the engine didn't sound so great. I have changed oil on many different vehicles numerous times so I don't think it's anything I did wrong. I thought the guy at the parts store could have given me the wrong filter because it's longer but after researching it looks like that normal with the Napa golf series filters. Can anyone help me PLEASE!!!!![EEK!](https://landroverforums.com/forum/images/smilies/bmHv6Xb.png)
Did you check the oil before you drove it? Have you check the oil SINCE you drove it? Sounds to me that you didnt cause you didnt put enough oil in the engine especially with oversized filter.
Either that or the new oil cleaned some sludge and you need to clean the oil pick up now. The oil light means your either extremely low on oil or oil pressure. Now you just need to figure out which one it is and why.
Just so you know, the engine takes 7, count them, SEVEN quarts of motor oil NOT 5.
Also, 5w-30 is the WRONG OIL for these engines.
The oil filter you used is a great choice, but not the oil.
Add 2 more quarts, drive it for a few weeks and then change the oil and filter again but this time use the correct motor oil, Shell Rotella, either 5w-40 for cold climates or the 15w-40 for the warm ones.
I dont know where you live so I cant say which one to use.
EDIT:I re-read your post, you live in GA, Shell Rotella 15w-40, SEVEN quarts, buy it by the gallon at Wal-Mart, about $12 per gallon. If you kept driving after the oil light came on, and it sounds like you drove for 10 miles with it on, you seized the engine. Thats why you lost power and the check engine light came on. You now have a new to you boat anchor.
Just buy 2 quarts from the dollar store, add those and see if she will run.
If so then change the oil again in a week like I already said and switch to the correct oil.
No there is nothing you can add to "balance" out the oil viscosity.
Just add cheap oil, if the engine is toast no need to waste good money at this point.
And just a FYI, the guys at the parts stores are idiots, they only know what their computer tells them and 98% of the time they dont even know who makes Land Rover, they think it is made by Toyota.
