need help tracking down a fuse
Old Jul 18, 2012 | 12:39 AM
collin Barrows's Avatar
Default need help tracking down a fuse
Hello, I've been trying to find the fuse for my licence plate light, both bulbs are good and the voltage is zip, so this leads to a blown fuse, I've looked in the Rave and owners manual. Any help would be greatly appreciated!
Thanks
Collin
Old Jul 18, 2012 | 12:52 AM
Bkreutz's Avatar
Thanks
Collin
Don't think it's a fuse, the power for the license light is tapped off the left taillight, so if that's working it's not a fuse. I'd suspect a broken wire somewhere. (or a corroded connector) I think the junction point is under the headliner on the left side at the rear. The first place I would check is the wire harness between the rear door and the body, after so many open and close cycles the wires have a tendency to break there.
Edit: It would also be helpful if you included the model year of your truck in your signature line, there are differences (minor) between years.
Old Jul 18, 2012 | 04:21 AM
And if not the connector 415 area, also consider the E401 ground area, which is a separate path from the tail lights. See attached.
File Type: pdf
File Type: pdf
File Type: pdf
Old Jul 18, 2012 | 09:19 PM
Danny Lee 97 Disco's Avatar
Could easily be a corroded ground or a wire fracture like Savannah said. Time to do a visual.
stb616
Oct 17, 2014 08:38 PM
Phatrowles
Oct 6, 2013 12:00 PM
cipher982
Jan 11, 2013 12:44 AM
glassman66
Feb 16, 2012 12:17 PM
slave600
Feb 28, 2009 02:33 AM
