Need polyurethane panhead bushing for steeing
Guys,
Tales of woe here
Long story short - oil leaks from the D1 engine are falling onto the
driver's side pan head bushing and rotting the rubber
in 3 months and then the steering goes to heck.
Garage keeps putting in rubber bushings.
Does anyone have a part number for polyurethane pan head bushings?
I gotta get those in.
Wife is saying "new car again".
All because of a garage putting in inferior parts.
Found this link from my last tale of woe on this same subject..
How to replace?
special tools needed?
Lucky8 Llc. - Take the road less traveled...
Thanks guys,
J
Tales of woe here
How to replace?
Thanks guys,
J
Just ordered these from Lucky8.
Any tips for putting them in -
I will be out in the parking lot.
Your order summary
DescriptionsAmount
Your order summary
DescriptionsAmount
- Item total $33.00
- Shipping and handling:
$12.00
- Total $45.00 USD
Thanks for the catch guys.
Just put in another order for panhard GAL114B
bushings.
Hopefully the oil will not rot these.
How hard is it to put these in?
I have not done front end work in years.
Just cylinder heads and all that.
I'll be glad if the steering holds out this time more than three months...
bushings.
I would imagine your radius arm bushings are probably just as bad. Must be a heck of an oil leak to make your bushings to bad that fast. I am inclined to believe that you have something more going on with your steering components.
With that being said, I just replaced all of my suspension bushes with polybush. Your biggest challenge will be getting the old bushings out of the panhard rod. I opted to not bother messing with it and took it to a machinist with a proper press. The new bushes are halved and mush easier to remove/replace should you need to do this again.
Getting the bushings out of the radius arms and panhard rod can be a huge pain in the ****. I have a small 12 ton press for setting up diffs that didnt want to push out some old radius arm bushings for ****. Lucky for me my buddy has 40 ton press that makes it a 5 minute job. If your in central Iowa I can help you out..
If not I think I have a used Panhard bar I can send you with the bushings pressed in if you want and you can just send yours back.
JimmyG
May 28, 2014 06:38 PM
middleman496
Jul 10, 2010 12:26 AM
