New Disco owner
I cant seem to get that icon off the dash. I tried messing with the stick and shifting it right and left. It doesn't seem to move right and left only forwards and backwards. Am I missing something? Im following all the directions on that sticker, shift to neutral etc...
i was ripping on it pretty hard. is it possible the light stays on even if it’s as far right as i can get it? i was moving it a little left and right in high and seemed like it was moving a little
I believe the car makes a buzzing noise if not fully in gear. It did it once for me.
I can get it locked easy, but I have to open my front door and lean into it pretty hard to get it unlocked.
If the light isn’t going off, drive around a little bit on a dirt road. Maybe some movement will help. You’re doing it right by being in neutral. Maybe try park? Just throwing out ideas.
Don’t force it. It shouldn’t be forced. It may need some encouragement but forcing it with excess will damage something. Sometimes a forward motion between 0-5mph helps
Can I lubricate the assembly somehow? I tried spraying some lubricant down there a year ago and didn’t see a difference.
Like someone said above, not being able to open the door from the inside is likely a bad door spring. There aren’t any really good videos out there, but you get can the springs from a company called x8r. Once you have the unit out, you’ll figure out how to replace them. One spring is included for each door, and one for the hatch.
For the rear, since it’s only the outside, it may just need to just be adjusted. There is a great video on YouTube on how to adjust the handle pull.
I was having the same issue, well sort of. At first couldnt open form the outside, took the door panel off, there is a twisting rod, giving it a bit more tension made the outside work. I was happy put it all together, closed the door, then the inside handle wouldn't work nor the outside.... After working to get the door panel off while the door being close, lol. I was able to readjust the rod and now am able to open both form inside and outside. It should take 30min, just dont forget to leave your door panel off as you open and close your door to test functionally.
here is the video
