NEW HERE! 1996 Land Rover Disco
Yes, live in Kennesaw, GA.
But hey now I'm overheating at red lights, slow speeds, and stop and go situations. Will overheat to top of white line, not red. On freeway or driving fast, cools down.
Coolant is BOILING!
I know to check thermostat, water pump, fan, and fan clutch, and fuses.
I don't want to drain coolant. any easy way to check stuff?... or any more reasons it could be overheating?
Coolant is BOILING!
First start with the belt routing, there is a link on the correct routing in the tech section.
This sounds like a bad fan clutch.
Check the tech section for the Chevy fan clutch modification, it will save you a ton of money.
