New problem, feels like it's gonna stall when driving...
Old Feb 12, 2011 | 06:21 PM
dansgt's Avatar
Default New problem, feels like it's gonna stall when driving...
So I've got a new issue as of yesterday, when I'm driving on the street the truck feels like it's gonna stall randomly while driving. Doesn't do it on the freeway or under heavy acceleration, just driving on the street at street speeds, mostly slower. My first thought was trans slipping but the engine would speed up then not drop in rpms rigt? She doesnt actually stall just kind of loose rpms and momentum and then go like normal. Cant tell if its while shifting or what, too random and so far no pattern to it. Any help is appreciated.
Old Feb 12, 2011 | 06:31 PM
thehun's Avatar
check your throttle linkage adjuster right by the TB. I had the same problem and it just lost adjustment and all is well now
Old Feb 12, 2011 | 06:34 PM
Next time it feels like stalling shift into neutral and see what happens.
Do the rpm level out? Does it stall?
Old Feb 12, 2011 | 06:42 PM
dansgt's Avatar
So it just got loose? God that would be a releif imma go look now lol
Old Feb 12, 2011 | 06:43 PM
dansgt's Avatar
It's so quick Its back by the time I can react. I did have it do it in 3 at a constant speed though.
Old Feb 12, 2011 | 06:57 PM
dansgt's Avatar
Well the throttle cable was very loose, I'll see on my way home if that was the problem.
Old Feb 12, 2011 | 07:11 PM
There is a TSB on the TPS for a DI I just found out.
Old Feb 12, 2011 | 08:05 PM
Spencerfitch's Avatar
trottle cable doesn't matter. Thats what the IACV is for.
Clean IACV
Old Feb 12, 2011 | 09:35 PM
dansgt's Avatar
actually its not that, i had a suspicion that it was gonna be fuel related...it is. i left work and as i was getting on the freeway i lost my fuel pump. i'm thinking its the relay thats sitting under the leak in my windshield....if you need glass, dont go with safe lite, it's been a nightmare since they touched it...
Old Feb 13, 2011 | 12:18 PM
Danny Lee 97 Disco's Avatar
If you got water leaking on your relay, it is probably shorting it out or you may have corosion build up already.
